looping through repeated items of array with only one for
ahmedsaber
Junior Member level 1
Al Jizah, Egypt
hi all , in C :
if i have an array contains repeated scattered items , and i need to make this array has no repeated elements but i ,must use only one for loop , how can i do this ?
You need to compare each item with all the other items. It requires nesting a for loop inside another.
The only way you could do it with a single for loop, is if there is a one-line command in C which automatically compares all items in an array.
