Looking for VHDL code for TCP/IP
Re: VHDL code for TCP/IP
AFAIK, TCP/IP is a software protocol.
Ethernet controller is implemented in hardware not the TCP/IP
Amr Ali
    V
After you implement the Ethernet controller in the hardware, you will need to port a TCP/IP suite to your platform as well as an Ethernet driver.
There are several options, but check out the following package that will get you started in the right direction:
IwIP
As far as the hardware you'll need to select some core depending on your application, check out:
OpenCores
FPGA4Fun
Here again they may not be best suited for your application, but they will get you started in the right direction.
