Looking for USB2.0 PHY IP
visualart
Advanced Member level 1
+umc +synopsys +usb core
I have some IP to exchange with u.
Tia
visualart
Either is OK.
It is better verilog or schematics
CatKing
Full Member level 3
no phy constructed by verilog, it's analog design!
maniasonic
Member level 1
...but PHY should be an analog ( hence hard ) ip therefore it must be quite foundry dependent...
huxuefeng
Newbie level 1
Please refers "www.opencores.com", U can find USB2.0 PHY IP.
visualart
It is useless in the Opencore
mitchell
Member level 3
I really want to find the USB2.0 transceiver , The
schematic and layout .
oasis
Junior Member level 1
as i know, usb phy is designed in the pad. and you could get some information from the ip providers, such as globleunichip in Taiwan.
ic_design
Junior Member level 3
Yes, PHY must be designed as an analog block, so must base on one process.
zyphor
Full Member level 1
can you provide the information of your phy's successful foudry?
visualart
who can provide the schemetic for us? Tia
bigrice
China
how do you say that?
I made it by using some src of Opencore's
visualart
I main that the free IP have many trap. and thank u , I got to the IP verified by silicon .
gold_kiss
Full Member level 4
The USB 2.0 IP has a combination of Analog and Digital logic design blocks.
The basic analog blocks are Drivers and Pads. While the Digital logic is the USB Core.
You can get one using Synopsys Design Ware. Or for UMC, ISI, GlobalUnichip...etc.
ARC
Thanks,
Gold_kiss
iamchine
Junior Member level 2
P.R.China
Agree with Gold_kiss,the USB 2.0 PHY IP has a combination of Analog and Digital logic design blocks. While the basic analog blocks are not only Drivers and Pads but also Analog PLL for 480Mbps high speed transition.
So it depends on which foundry's process you select.You may ask the foundry for the ip or third-part ip provider.Then you can exchange IP with the provider.
visualart
Thanks ,gold_kiss & iamchine.
I got to the USB 20 PHY IP verified by silicon .
I main what I shall provide if I design a analog IP. thank u .
