Register Log in
Looking for schematics of 4km Range FM Transmitter
richmon74
Nigeria
4km fm transmitter
i need to make an FM Transmitter that will cover 4km radius. Is anybody with such a schematic and is willing to share? links could be useful.
i ran into the page in the attachment below (i can't get the link to that page online anymore that is why i had to post it) and i'm ready to use the circuit there but antenna is my prob. I dont know about antena designs but a guide could make so much good
the linke to the design of their antenna in the page is'n alive so i want someone to help me go through a design of antena to suite the schematic there
N/B: i am very bussy i wouldn't want to go through the stress of reading on antenna design now.
mr_ghz
Full Member level 5
Hi richmon74
I see following possibilities for your antenna:
1.) Using a lambda/4 antenna. This antenna has a pattern similar to a donought cutted in the middle. I think it is useful for broadcasting FM radio. It is built of two parts: a good ground (earth) and a wire with the length of 1/4 of lambda. In your case (100 MHz) the length will be about 0.75m. This wire has to be orthogonal to earth. At the feedpoint you connect a coax directly to earth and this antenna (inner conductor). On your transmitter you can connect this cable without a balun to C11 (without C12). The impedance of this antenna is near the output impedance of 75Ohms.
2.) Using the suggested dipole. To build this antenna you use a wire (about 1mm diameter) with then length of lambda (3 meter). You create a form looking like the one in the page. The distance between the upper and lower wire should be some cm. The complete antenna will have a length of about 1.5 meters and uses the described balun to connect. This antenna has a little bit more gain (= range) than the first one.
3.) Using a Yagi. This is a directional antenna. So only people inside this area can hear your signal. Is this what you want?
Bye
richmon74
Nigeria
Bye
actually i would like it to cover a circullar radius of about 4km
Borber
Advanced Member level 5
on third flor
j-pole
Use j-pole antenna. There is a lot of projects for fm on the web.
richmon74
Nigeria
Re: j-pole
that's true but funny enough most of them don't work
Toggle Sidebar
