Looking for RS232 API functions for VBA
tgq
Full Member level 5
vba rs232
Hi
VBA doesn't support MSComm activeX :cry:
Im looking for a 'ready to use' VBA module for RS232 API functions.
Best should be class module with events on character received on COM port ...
btbass
Advanced Member level 5
Oberon
rs232 api
Download VB express from Microsoft. It is a free download. It has a commport you can just drop on your form which will expose the comms api.
mmelsadek
Newbie level 2
Egypt
rs232 vba
Hi there
the API functions for serial port are as follow:
1- to Open the Port use:
CreateFile()
2- to Configure the port use:
SetupComm()
SetCommTimeouts()
GetCommState()
SetCommState()
3- to read from the port use:
ReadFile()
4- to write to the port use:
WriteFile()
5- and finally to close the port use:
CloseHandle()
Please refer to you compiler documentation for more information about these function, I use it with the Borland C++Builder and worked well in so many projects
Good Luck
eziggurat
Full Member level 6
vba api rs232
Hello,
I am also trying to access the serial port using VBA on Excel.
I have tried using CreateFile(strPort, GENERIC_READ Or _
GENERIC_WRITE, 0, ByVal 0&, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, 0)
to open the port where strPort is "COM5" (USB serial device) but I always seem to get a -1.
Any help will be great.
