Looking for routine to debounce buttons in C
micpic
Junior Member level 3
c debounce
Hello,
has somebodey a routine to debounce some buttons (written in c)?
I am searching for something which worjs without delays, so that the µC isn´t blocked while debouncing.
debounce em c
u don't require special routine for for debouncing u might make some small delay routine then check again if the button is pressed
Re: Debouncing in C
You could use a while loop like this:
int button=0
//when the button is initially pressed, set the variable button=1
while(button == 1)
if(button==1)
button==1
elseif(button!=1)
button=0
break //break out of the loop once the button has been let go
endif
end
Re: Debouncing in C
micpic said:
Hello,
Then use timers , and timer interrupt
/Bingo
Debouncing in C
you can use a rutine in timer
like
if ( key != old_key ) {
debounce--;
if ( debounce == 0 ){
key_pressed = key;
debounce = 100;
else{
debounce = 100;
