Looking for replacement of Teccors L200X to drive a triac
Elavionic
Member level 5
Portugal
Triac and µC
I'm using a PIC12f508 for a small project. At current time i'm using a moc3041 (optotriac with zero cross) to drive a triac (BTA600-08). My plan is to remove the opto. I know that are some logic level triac or sensitive gate triac. I already had a sample code for zero crossing detection.
I find L200X from Teccor an excelent choise but they are hard to find, so i'm looking for others.
Thus anyone ever worked with one of this?
If so wich one?
Can you give me some examples?
Thanks in advance.
flatulent
Advanced Member level 5
Middle Earth
Re: Triac and µC
There are some serious safety and legal issues you will face by not being opto isolated or other type of isolation. One way around these is if your entire controlling and switching circuit are enclosed in a double insulated box.
Elavionic
Member level 5
Portugal
Re: Triac and µC
I know that isn't safe but thats no problem. The enclosure is plastic with IP67 protection. The power supply is very simple ( no transformer based) so all the circuit isn´t isolated, and for that reason i don't need an optotriac (reduces project costs).
aNdreiBuuu
Full Member level 4
moon
Re: Triac and µC
There is another problem... the gate current must be over 50mA... for opto diac the command curent is reduced to 5-10mA. Your power source is enough to supply energy for your board?
hope this help,
//a
rauol
Full Member level 6
India
Re: Triac and µC
one more problem with direct driving,
if the Triac or its associated component fails your µC can get damaged.
maranaza
Member level 2
Re: Triac and µC
I could't read from your post full part number, so I don't know the rated current of your triac. If it is not too high, you can get sensitive gate version from Phillips or ST. You can drive 10 or 16 A sens. gate triac from uC. If you have spare uC pins, connect them in parallel to drive the triac.
maranaza
Elavionic
Member level 5
Portugal
Re: Triac and µC
Thank you all for the tips. I find, at ST, some sensitive triacs with only 5 to 10 mA gate current for load up to 10A, more then enought for me. When i make it work i'll post the schematic.
