Hi Guys,
In my project, I need to control Home appliance (like turn ON/OFF them) over wireless network. I am using a micro controller based small hardware board that receives the commands over wireless. The board has digital I/O pins. I am thinking of using a relay that will be connected to these pins.
On receiving the ON command, microcontroller will set voltage high on that digital OUT pin, so that relay will be CLOSED and Appliance will be connected to AV power/ Wall Plug. On the other hand, when OFF command is received, relay will be OPEN.
The analog out voltage on digital pin is 3.3 V TTL. I need to use an amplifier to boost voltage to 12 V DC required for the Relay.
Please suggest me any good relays
