Looking for Philips 29PT720B00 service manual
BGA
philips 29pt720b00
Where to find servce manual for:
PHILIPS 29PT720B00
Thanks in advance.
adedia
Member level 2
Yk ID
Philips service manual
try track this site
hxxp://www.euras.com/repair_tips_1/Philips/29PT720B00/29PT720B00_Philips.htm
BGA
Re: Philips service manual
yes, but where to fnd schematics atc. etc. I must repair my tv..
help!
Added after 17 minutes:
My 29PT720B00 have the following problem described in Euras:
"Starts up but then only slight pulsation".
Any help?
BGA
Not yet... I didn't fix the problem.
Do you have EURAS? ... it's very interesting for video repair
pit
Full Member level 4
PHILIPS 29PT720B00
Please post the chassis type here. Schematics are always sorted by chassis type.
Then I may help you.
Added after 22 minutes:
Possibly the TV is equipped with GR2.4 chassis. Please find the service manual attached (schematics included).
Concatenate the two parts before unzipping!
BGA
Yes, my chassis is gr2.4aa.
How can I concatenate the two files? The archive seems to be not working.
pit
Full Member level 4
Hello!
How to concatenate your files depends on your operating system. With Unix, Linux and similar use the cat command:
cat >Philips_GR2-4_chassis.zip Philips_GR2-4_chassis-part1.zip Philips_GR2-4_chassis-part2.zip
With MS-DOS you can use the copy command, remember to use the binary option! Mac-OS should follow Unix command style.
Then you can unzip the archive. The archive works, I have tested it before uploading. Unfortunately the maximum file size allowed here is 5 MB so larger archives have to be split in multiple parts.
CU
BGA
Nothing to do under Winxp... I used winzip and winrar without success.
Any help?
pit
Full Member level 4
Any help?
Use copy command with MS-Windows, remember to set binary option as I already described! You must concatenate the two trunks before unpacking, otherwise it won't work. The archive works, I have tested it before uploading.
I haven't used MS-Windows for years now... so my memory for the correct syntax has faded away... could be something like
copy sourcefile1 /B + sourcefile2 /B destinationfile /B
CU
BGA
Who can make this operation for me and put on line a winrar or winzip version?
pit
Full Member level 4
Why don't you use the copy command as described?
CU
BGA
Thanks a lot... now it work. I didn't use /b.
