Looking for pH water meter schematics
mostrengo
Member level 4
Member level 4
LSA
ph meter
I need links for schematics for a pH water meter for aquariums
thank you
House_Cat
USA
Here are links to a couple of schematics. The first one looks like the best of the two.
h**p://www.lce.org/equipment/phmeter/phoper.html
h**p://www.cyberreefguru.com/electronics/index.html
jjchl
Newbie level 6
Newbie level 6
spain
Hello,
The PH probe give you an equivalent voltage. You must amplify the signal from the PH probe and compensate it.
Roscoe
Member level 1
Member level 1
Germany
Hi jjchl,
the input resistance for the ph Meter must by verry hig. The ph electrode has an output resistance in the range of minimum 200 M-ohms, or more.
You must use an input OP with very low current and low bias.
Next week ( i'm in hollydays and not in the office) i can send you a schematic of a industrial ph preamp.
Send me pm if you are interested for this.
roscoe
majid_valentine
Junior Member level 3
ph meter
hi all
i need a digital flow meter circuit can any body help me????
