Looking for materials about EL inverter
brahmanlar
Newbie level 6
Newbie level 6
I need an EL-inverter
inverter specifications.....
input = 12V DC
output = 80VAC ~100VAC
output frequency = 0,45kHz ~ 0,85kHz
is there any body that has document or circuit diagram to make this inverter myself..
or any data sheet or any application notes..
thanx for now..
EL inverter
thanks Awarapunshee,
this circuit helps me much..
but want be able to change the frequency or output voltage while using it...
can you have any ideas about them..
thanx again..
Re: EL inverter
You can change the frequency from the pot 25K (freq. adj written on it). A little bit voltage change occur by changing frequency but you have to change transfer turn ratio for the increase.
Regards
    brahmanlar
