Looking for low power low voltage Astable circuit or 2-4 hz frequency
ehsan_r34
Member level 2
Hello.
Please give me a low power low voltage Astable circuit or 2-4 hz frequency.
Thanks
Re: Astable circuit
try using a 555 IC... it is very stable circuitry for low voltage as well as low frequency requirements that you have.....
Re: Astable circuit
Thanks
But it work at 5volt.
I want to work at 3volt.:?:
Re: Astable circuit
then use the circuit using two transistors.... it will surely work for 3V and less... these circuits are even available in market pre fabricated in a PCB....
Re: Astable circuit
The CMOS tlc555 timer works from 2V to 15V.
http://www.ti.com/lit/gpn/tlc555
Also in SMD and dual TLC556.
    ehsan_r34
Astable circuit
Thanks
I need very low power and reliable Astable circuit for driving LED with 15-20mA.
Do u think 555 do it?
Re: Astable circuit
the 555 IC can sink a current of about 15mA..... the circuit i told you of can drive 2 LEDs at a time.... i bought a readymade module of it which uses 3V to do so.....
Astable circuit
How dose it drive the LEDs.
Re: Astable circuit
it has two LEDs connected across its output in parallel......
Re: Astable circuit
Check Rashid or Bell
Re: Astable circuit
You could use either device ,I just pointed out the TLC555 can work down to 2V.
To answer your question you could hook two LED's up in parallel from the Vcc rail to the output cathode to the output of the TLC555 timer with current limiting resistors.The TLC555 can sink up to 100mA (sources 10mA). The LED's will just go on when the outputs low and off when its high.
Here is what is meant by sink, source current,and how to hook your LED 's up.About 1/4 way down the page.
http://www.kpsec.freeuk.com/components/ic.htm
