sapphire
Member level 3
how to bias VCO
Hi Guys,
I am designing a CMOS LC VCO at 5GHz. The VCO is powered by 1.8V. And I biased the gate voltage of tail current transistor directly using a power supply(say 1.1V). When the chip come back, the measurement shows it can oscillate at right frequency but the phase noise performance is pretty poor. The 1MHz offset has a PN of -70dBc/Hz, while the simulation gives almost -130dBc/Hz. I guess it's a problem with the biasing. Then I re-simulated the VCO again in ADS with a 1uV V_Noise componenet in series with each power supplies, and it shows a 1MHz PN performance of around -70dBc/Hz. I want to know how the VCO is biasing ususally? Do I need to build a biasing network and using current mirror structure? Is there any useful link for a quick review? Thanks a lot in advance!
Ed
Hi Guys,
Ed
