Looking for information about PIC24F configuration
kotsam
Member level 1
pic24f
Hi Guys ,
I willing to start programming PIC24F , the point is when i was programming PIC18F i had webpage that has almost all the configuration
https://www.electronicfr.com/index....emo-and-code-exemples-for-C18-programing.html
which it was very usefull for me so is there any webpage like this for PIC24F more over i willing to use LCD and PWM but i couldnt find header at pic24f Peripheral Library so can i use the one from PIC24H? if not do anyone know from where can i find these header not PMP . thanks for any help
GSM Man
Banned
New Jersey, USA
header files mplab pic24f
You don't say what compiler you are using, but I assume it's Microchip's C30. If that's the case, most of the information you need can be found in the documentation folder. If you used the default install directories, it should be located at: "C:\Program Files\Microchip\MPLAB C30\docs\periph_lib". Start with the HTML file "16-bit Peripheral Libraries.htm".
    kotsam
btbass
Advanced Member level 5
Oberon
pic24f headers
The PIc24 configuration is so much easier than the Pic18 configuration.
Three or four lines at most.
Setting up the config for a Pic18 is a f...k..g. nightmare!
kotsam
Member level 1
pic24f c30 config settings
Thanks Alot guys that was very helpful ...
Added after 2 minutes:
i have another question though , can i control LCD Contrast and Backlight by using PWM ???
Tahmid
Silicon Valley, California, USA (from Dhaka, Bangl
pic24f configuration
Hi btbass,
Setting up the config for pic 18F is also very easy provided you understand it. Please take the datasheet of anyone of the Pic 18f Micro and carefully go through the configuration details and you will find it very easy. You have to invest some time to understand those properly. Thanks.
