Looking for information about multicycle path
pradeep2323
Junior Member level 3
can anybody tell more regarding multicycle path?
mcpdevs
Newbie level 5
Bangalore
multi cycle path
It's nothing but a single path in the netlist activated by more than one clock domain.
p_shinde
Full Member level 5
tokyo
what are multi-cycle paths
when a data takes more than one clk cycle to travel from one flop to next flop its called mutli cycle path
echo47
Advanced Member level 5
USA
why multicycle path
Xilinx says, "a path between two registers with a timing requirement that is a multiple of the clock period for the registers".
It is commonly used to relax the timing constraints in sections of your design where the data timing is relatively slow or uncertain compared to the clock rate.
thamarai
Member level 1
multicycle path xilinx
The path, which takes more than one clock pulse to reach next flop is called as multicycle path.
vasuruta
Newbie level 3
what is multicycle path
Multicycle path (MCP)is a path which takes more than one clock cycle to output the data.
Setup and hold calculations will be different for MCP.
Usually multicycle path is seen in adder, multiplier design. It takes more than 1 clock cycle to update the output.
Such kind of combinational path has to be declared as multicycle path in DC(synopsys). Otherwise tool tries to optimize it and take huge amount of time and goes into loop. :?:
chanpreet
Newbie level 3
defining setup and hold on multicycle paths
multicycle path comes into picture when the data lauched by a flop takes more time than the clock period itself, hence we can capture the current data in the next clock cycle. Also we can apply multicycle path if the lauch data is stable for more than one clock period therefore the capture flop dosent need to catpure the data in the next cycle it can capture it in next to next cycle.
Hards
Member level 1
timequest multicycle
When a data path is too long that can not be completed in one clock cycle then for that perticular path we have to define mulfi-cycle path.
