Looking for information about bidirectional buses
verilog_always
Member level 2
I want some information on bidirectional buses. Can anyone provide it?
Re: Bidirectional bus?
back to back buffer with inverted enable pin .
Bidirectional bus?
Same line we can use for sending o/p and getting i/p using a ctrl signal.can you tell what exactly you are looking for?
Bidirectional bus?
bidirectional bus is used for transferring data to both side.... but if you tell us what you want ... then i can tell you specifically.
On single line data transfers occurs on both sides by using some contrl signals
Bidirectional bus?
Pls check the Xilinx library documentation.
Bidirectional bus?
bidirectional bus is tranferring data both side
in using verilog it can be using wire
wire out=recive_data?reg to buf:8'hz;
Added after 12 seconds:
vamsi
