Looking for hex file for cygnal ec2
bigwavek
Newbie level 6
hello ..
Is there someone who has the hex-file for cygnal_ec2 ?
mitesh
Full Member level 3
cygnal ec2
Hi Bigwavek,
What excatly do u want for Cygnal, Which hex file do u want for cygnal _ ec2
bigwavek
Newbie level 6
silab protel
Want to make cygnal_ec2.
It knows what work H/W does.
By the way, cygnal_ec2 flash takes lock.
So, can not know hex file.
vladnick
Newbie level 2
ec2 programmer
That is EC2 HEX-file. And another one is ZIP-archive for EC2.
Reactions: inseminoide
    inseminoide
    V
UroBoros
Advanced Member level 2
Cochin - India
ec2 usb
Hai,
I am using a Cygnal Development sytem with EC2. I am interested in knowing the details about the system. Which is the format of schematics and PCB. Protel? Give me a link to download the tool please!!
Can you provide some links and details about JTAG debugging and all?
Can we use this EC2 to debug any other controller with DIP versions like 89C51 or somethoing like that?
Picstudent
Make_Pic
Member level 4
ec2 firmware hex
Picstudent said:
Hai,
Picstudent
You cannot use this device for debugging 89C51 other manufacturers.
It is intended for debugging only MС C51FXXX CYGN@L.
aNdreiBuuu
Full Member level 4
moon
rs232 adapter for cygnal microcontroller
this ec2 programmer/debbuger work with cygn@l IDE?
thanks,
//a
Make_Pic
Member level 4
rice programmer cygnal
thanks,
//a
Yes, this device (EC2) works with IDE CYGN@L very good!
eltonjohn
ec2 programer cygnal
The XTAL appears to be 18432Hz???? This can't be right ?
why such an odd freq .. This chips have UART and internal oscillators .. does any body can comment on this?
I'm enclosing the pdf equivalent of the schematic
There is another programmer called the RICE programmer at :
https://www.graphord.com/articles/RiceProgrammer.html#d3e46
Zed@001
Newbie level 2
cygnal ec2 schematic
Hi my name is Zsolt. We are just getting started to deal with Cygnal controllers
at my job. We bought he original IDE from Silabs. But I would like to build a
home made programmer for myself. Can I use these EC2 file for the programmer?
gsmsupport
Newbie level 2
sylabs_ec2_v10_cz.pdf
Hello
I built Rice Programmer https://www.mozzarella.jp/hardware/c8051f30x/index.html
Please tell me if I can use max232 instead of ADM232A ?
Is c2avr.hex for at90s2313 ?
Which software should I use for windows with Rice Programmer ? Can I use Silicon Laboratories IDE or is there other program ?
How to test if programmer is working correctly ? Plese HELP.
mirkom
Newbie level 1
programmer ec2 for c8051
I have burned my EC2. It contains c8051f012 and I can replace it, but and I need firmware (hex file) to load it. Can anyone help me please?
Mirko
zpc
Junior Member level 1
silicon lab hex file
Hi eltonjohn:
I look the XTAL,it's 18.432MHz.good luck.
ZPC128
jan noha
Member level 1
riceprogrammer
If you are interested in EC2 cloning, see h**p://www.mcu.cz/files/products/SyLabs_EC2_v10_cz.pdf. It is in czech, but the schematic is easy to follow.
zpc
zuec3
"czech schematic" use "EC2-HEX.zip"
can work fine?
brbl
Newbie level 3
circuit ec2 c8051f012
what can use tools that it is load Hex file to c8051f012?
abcllz
Newbie level 6
silabs ec2 hex
the other silab JTAG Programmer Schematic & Source code
Added after 4 minutes:
the other Cygnal JTAG Programmer Schematic
usb to uart
OurWay
Newbie level 5
ec2 silabs clone
This can use?
