Looking for Encounter log file
p_shinde
Full Member level 5
tokyo
Re: Encounter log file
pls find enc log file
pyth2004
Member level 1
For the auto place & route, you can follow the steps in the below link:
https://www.ece.ncsu.edu/muse/fe/counter/
There are some errors of your config files(.conf). You can set them in the GUI of Encounter, so you no need to import your config file.
Only 4 files you need to import to the Encounter:
1. .v (your synthesized netlist)
2. .lef (technology library)
3. .tlf (timing library)
4. .io (footprint) import if you have this file
**ERROR: Die Area is not defined
**ERROR: Standard Cell Region is not defined
**ERROR: Incorrect height (0.000000)
**ERROR:
Before you can do auto P&R, you need specify the core or die area (the area allow the metals to route).
This parameters can be set in Encounter GUI:
Floorplan -> Specific Floorplan
1. Set Core/Die Size (height and width)
2. Core to IO/Die Boundary > 0
Hope this can help you
:D
Added after 5 minutes:
This is a good tutorial for Encounter
horzonbluz
Full Member level 4
Oh, no.
It's too simple ones. If you have some good manuals than this one?
steven852
Your Tcl file is not correctly configured.
