looking for developer kit for LMX9820
bumerang
Member level 2
lmx 9820
Hello,
Has anyone got a developer kit for LMX9820, I need documentation and software that comes with developer kit. Thank you
Re: lmx9820
I have two of the national LMX9820 evaluation kits. I'd be happy to send you some documentation. Along with some design pit-falls I've encountered.
Pete
Re: lmx9820
Hi Pete,
Could you please send me "simply blue commander" and reletad documentation. Thank you for interesting.
Kevin
I could also use documentation on the LMX9820. Thanks.
Re: lmx9820
Hello:
I'll appreciate a lot if someone send me documentation about the lmx9820 module.
Tanks in advance
Re: lmx9820
Hello I´m a student and i do my Dipl. Ing. work about bluetooth. i have got an example of the LMX9820 but without of the documentation for it. I build an PCB an try to test it, but no chance to find the chip in the Bluetooth environment. (I have no antenna on the chip and used a simply wire with Lambda / 4 witout the RF Network). If somebody has an idea of the RF network or the antenna or has the commando settings please please send it to me at JBaur@sysdesign-edv.de. The Picture from the board but not very good! In the middle of the module is the antenna.
Re: lmx9820
Hi, All. Is it possible to program the LMX9820 without the KIT directly from PC? What software I need for this?
Re: lmx9820
I've been away for a while. Does anyone still need help with the LMX9820? If so, let me know and I will give you what I have.
Pete
Re: lmx9820
Tips on the LMX9820:
-the chip won't work if the clock is off even by a wee bit. They spec.ed 18pf caps on the crystal, but I only got it working with 47pf
-Serial line sniffers will interfere with the firmware update software. Don't use them.
-If your BT module only outputs a 2 char code x18 x0f, your radio is in firmware update mode.
-If CTS drops 30 seconds after reset, you are in low power mode. change the input to HOST_WU.
Re: lmx9820
Hello, I have one of those LMX9820A but I need the information that comes with the Evaluation Board, because I don't have the opcodes or codes examples to work with the chip.
I have read that ther is people that have these information.
I would appreciate a lot if you send it to me please.
Thanks,
Francisco
Re: lmx9820
Hi!
I'm a student from Austria and I need help with the LMX9820.
I want to send digital signals from the ADuC845 to the PC via LMX9820. Programming is not my speciality so I'm helpless!
Has anyone a "C"-code that it works?
Re: lmx9820
HI
I'm interested by using LMX9820 with a host is AVR microcontroller. If anyone has informations, please indicate to me.
Regards
