Looking for Compact PSU ±12V Output PSRR 5μV/V (-106dB)
mr_76
Newbie level 6
Newbie level 6
Hi all,
I need a compact PSU with following specs:
• Compact size ~140X40 mm
• Unipolar Input Vdc (we are able to feed it with Vdc in the range 6~24Vdc)
• Power supply rejection ratio 5μV/V (-106dB)
• Output ±12Vdc
• Capable to deliver 100mA on +12V and -100mA on -12V
I'm still searching the web but 'till now i haven't found any product that fullfil these requirements
Can you please suggest me some brand or website that make this type of PSU?
Thanks in advance.
Best Regards
  • LT1945 - Dual Micropower DC_DC converter with Positive and Negative Outputs.jpg
  • LT1945 - Dual Micropower DC_DC converter with Positive and Negative Outputs.pdf
  • LTC3260 - Low Noise Dual Output from Single-Ended 15V Input.pdf
