Looking for books about digital receivers
davyzhu
Advanced Member level 1
oriental
Digital receiver book?
Hi all,
I am a newbie to digital receiver(ATSC,DVB-T,etc).
I want to learn about synchronization, equalizer, demodulation, etc?
Is there exist a book talk about digital receiver tech?
Or shall I read a lot of books and do some simulation?
Any suggestions will be appreciated!
Best regards,
Davy
The following information was needed at first,basically :
1) digital Electronics
2) Mpeg algoriths
3) DVB
4) Cryptography
5) Analogue Electronic
6) Satellite comunication systems
Re: Digital receiver book?
You might want to look at Transceiver and System Design for Digital Communications by Scott R Bullock. It is good introduction but is oriented more to direct sequence spread spectrum. But all the basics on demod/mod syncronization etc are there.
You need to study:
1.MPEG2-TS SPEC
2.outer coding(reed-solomon code & decode)
3.outer interleaving
4.inner coding(convolution code& decode)
5.inner interleaving
6.QPSK & QAM modulation & demodulation
7.OFDM(include IFFT & FFT)
8.sync.
i have asked in this forum about specific book titled" digital communication receivers"synchronization,channel estimation and signal processing" and i get the help
if u wanna this book,u can download it from the following link:
regards
the link does not exist can reupload it
try this,i think it is active link(digital comm. receivers book)
is there another book rather than the link above?
The link is removed, can anyone upload this book again?
The link is working properly.
I tried to access the link again, but I could not. Do I need to be a full member or something to download this file?
this link is not working
It's a good book,but it is difficult for beginning learner.
Good for luck!
the link which i gave is working properly.....
Hello Silawi,
Can you post the rapidshare link of this book in this in this forum? Thanks
hey,
the link is not working anymore..can u pls post another link..
Ranjitha
Anyone have read the book please give a comment on it.
Thank you.
hanm
Hello!
Digital and Analog Communication Systems, Sixth Edition by W. Couch, II is book which can help you in Digital Receiver.
The synchronization, equalizer, demodulation are very broad research area. For different communication system, there are different methods. As a starter, you need focus on a speific system such as DVB-H, understand the basic concept and then begin to work a particular problem for the digital receiver.
