Looking for books about C++ embedded programming
speedoak
Member level 1
I use C to develop hardware driver for a long time, I used to think C++ is not efficient to develop low level driver, but recently I found that by using C++ to develop driver is very good and interesting, anybody can recommend some C++ application notes or book on C++ embedded programming?? thanks
rbpij
Newbie level 3
Re: C++ embedded programming
Hi Speedoak,
Try to get from here:
http://ftp.cdut.edu.cn/pub3/uncate_doc/OReilly%20-%20Programming%20Embedded%20Systems%20in%20C%20and%20C++.chm
ilker
Member level 3
TURKEY
this book introduces a chapter about
Making our C programs "look like" C++
nj_jack
Member level 5
in general, c is a good choice for embedded programming. it is very easy to implement the interface between hardware and software.
terka
Hi
Have you a tutorial for learn to use CCS PIC C compiler??
Thank you
banh
Advanced Member level 1
a few compilers support C++,
but i think C++ is to help you apply all the concepts of OOP (inheritance,etc..)
as long as you have quite enough RAM...
SphinX
Advanced Member level 3
EGYPT
terka said:
Hi
Thank you
An Introduction to Programming The Microchip PIC in CCS C
Bye
banh
what is CCS C?
irfansyah
New South Wales
I want to know from your experiences, which is more desirable in embedded C programming? Declaring variables as global variables OR using local variables in functions?
Sometimes i avoid creating functions with more than 1 parameter, because it seemed that the stack memory requirements increases. I also prefer using global variables then using local variables for the similar reason. Are my assumptions correct? Anyone has any suggestions for better C embedded programming?
salam,
irfan.
banh
using global variables means we always reserve certain amount of RAM for these variables.
So i suggest using least global variables as much as possible... usually only in the case of shared variables..
devennan
Member level 3
India
irfansyah
as you said that you avoid using function's with more than 1 parameter
that is good but what if you require a function with more than i parameter
also using global variable is not a good idea unless they are shared as they take memory for entire life of program at run time
use local variables
also declare local variables inside if() conditions so that only if actualy required are local variables declared and take space from heap
Added after 4 hours 30 minutes:
Use pointer efectively to improve the code
it improves the speed and is more compact
muko
Member level 1
C++ may be not efficient from the point of code size.C is very suitble for mid level mcu's.I advice C...
banh
devennan said:
irfansyah
can we do it? i think most C compilers ask us to declare variables at the beginning of the function..
Jack// ani
SphinX said:
terka said:
Hi
Thank you
h**p://
Bye
Is this book completely uploaded?
trashmen
Newbie level 3
The best method for variable declarations.
as you know local static variables are invisible outside the prodecudure, globals are visible everywhere in whole program.
But in my oppinion, when you are declaring variables, you have to choice:
- "good school" looking
or
- "experience school"
The first you can found in each book - declare static variables inside procedues, like somone described in upper text.
The second solution is:
When you starts new embedded application, you should put all variables (globals and local static) in one header file.
Thats gives you opportunity to easy make application test, better than with static varibles hidden in procedures :)
When everything is tested, if you want, you can move all locall static variables declarations to proper places. I do so since 15 years and test time is strongly reduced.
Another metter is C++ on microcontrollers.
The compiled code size is the same like C.
The source code written in C++ is bigger than written in C for the same solution.
And programming is easier , thanks to C++ is higher level language than C.
If you don't belive - than try it ! To get your own oppinion.
banh
A short document on firmware programming standard:
https://www.ganssle.com/misc/fsm.doc
by Jack Ganssle
in which he discourages the use of global variables especially when there are a lot of them leading to debugging problems..
All too often C and especially assembly programs have one huge
module with all of the variable definitions. Though it may seem
nice to organize variables in a common spot, the peril is these are
all then global in scope. Global variables are responsible for much
undebuggable code, reentrancy problems, global warming and male
pattern baldness. Avoid them!
Real time code may occasionally require a few - and only a few -
global variables to insure reasonable response to external events.
Every global variable must be approved by the project manager.
When globals are used, put all of them into a single module. They
are so problematic that it’s best to clearly identify the sin via the
name globals.c or globals.asm.
FD357
Member level 2
Have anybody tried JAVA in embedded system?
