Looking for basic resources on I2C Bus
sameem_shabbir
Pakistan
how to configure the video encoder through i2c
I don't know anything about I2C Bus.
From where should i get some initial knowledge
Moreover my video decoder and the PGA are attached through I2C bus
to configure video decoder from FPGA
How should i do that
deepu_s_s
Full Member level 5
I2C BUS
do u want to implement I2C bus controller?if yes i am having some material on that.
nxtech
Full Member level 5
NO HIDDEN LINKS
Re: I2C BUS
Why dont you try using the search feature of this website? You would be suprised at what you will find.
E
sameem_shabbir
Pakistan
Re: I2C BUS
My video decoder chip is attached to FPGA via I2C(for programming)
I need to enable the output of the video decoder (which works only in slave mode)
The output is enabled via following way
I need to build an I2C master into my design(verilog programm). Then use that to load the value 0x6D into register 0x03 of the TVP5150. That will enable the YOUT[7:0] outputs
This was the reply send from the XESS company
Now i want to do it.
I did't understand what is 0×6D and how to use it
FvM
Super Moderator
Staff member
Bochum, Germany
Re: I2C BUS
Hello,
it's just a number in hexdecimal notation. In Verilog you could write 8'h6d instead. You have to consult the video-encoder manual to know what it means. I understand, that you have to write a single byte to register address 03 in video controller.
Regards,
Frank
manish12
Advanced Member level 3
Re: I2C BUS
phillips invent it in 1979 !
you refer there web site to explore more about it !
or you refer any iic device data sheet such as AT24C01 ,AT24C02 etc.
FvM
Super Moderator
Staff member
Bochum, Germany
Re: I2C BUS
NXP formerly known as Philips, the most recent I2C specification is here
