pmtwiss
Junior Member level 2
- Joined
- May 28, 2008
- Messages
- 21
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,283
- Location
- Pasadena, CA
- Activity points
- 1,502
Hello,
I am currently working on a design which pretty much pushes the possibilities with PCB design. Currently I can only find a single company capable of fabricating and assembling the design. I can find several companies to implement the fabrication of the flex circuit, however only 2 Ican find that can assemble it, and one of them is retarded.
*** Does not matter where in the world it is ***
Does anyone know of some VERY good PCB assemblers? Here is some of the requirements I need:
For Flex Circuit Fabrication:
- 1.5 mil trace/space minimum, typical 3 mil trace/space.
- Polygon pour spacing at 3 mils from all over objects all over the board
- 1-1.5 mil PSR opening (this is the opening of the soldermask to the pads), also can be thought of a soldermask tolerance
- Able to apply copper & soldermask up to 4 mils of the edge of the board outline.
- Reliable 3 mil minimum soldermask sliver
- ENEPIG plating
For Flex-Circuit Assembly: Remember, this is all on a flex circuit, NOT a rigid. This requires very good fixturing.
- Double-Sided Flex Circuit assembly. 90% on top, 10% on back
- Down to 01005 SMTs, which can also be placed even on the edges of the board, 8 mils from board edge
- WLCSPs @ 0.4mm Pitch, of all sizes, including a 2x2 (0.8mm x 0.8mm IC), and up to a 9x9 ball.
- QFN, LGA, etc.
- Only 5-6 mils spacing between SMT component pads
- Only 6 mils spacing between WLCSPs and 01005s
BONUS: If possible also able to assemble and wirebond dies. We do have a non-PCB Fab vendor for this but we'd like to find a one-stop shop.
If you know of any places that can do this or possibly close, please let me know, this is a big help for our project.
Thanks,
-Peter
- ENEPIG plating
- QFN, LGA, etc.
Thanks,
-Peter
