Looking for a transceiver chip that operates at 1.5 V
cusna
Newbie
Hello,
I designed a transceiver to 433 MHz using a CC1000 and a PIC, works well but I would reduce the size.
To use only a battery alkaline button to 1.5 V.
You know some product?
Thanks
PaulHolland
Advanced Member level 2
Holland
Re: Transceiver 1,5 V
Hi, This controller can run at 0.9v:
Maybe they even have a RF chip for you :).
scoperd123
Newbie level 3
Transceiver 1,5 V
Power from such a voltage would be very low, and potentially unstable, perhaps use a voltage doubler to get approx 3v, maybe a better soloution , a lot would depend on the compliance required , etsi, fcc , can be quite stringent with battery devices
cusna
Newbie
As I said to 3 V I have a circuit (CC1000 TI),
But I must use power for 2 from 1.5V alkaline batteries.
I tried to use a single lithium battery 3V (with the same size of a button battery from 1.5 V) but the problem is that lithium has not current and transmission after a few transmissions does not work.
Should I use lithium batteries for greater capacity but also increase the size.
The solution is therefore with alkaline batteries, but unfortunately there is no button at 3V and therefore must use two.
This tried a chip that could operate at 1.5v
The greatest need must be very small
PaulHolland
Holland
Use two zink-air batteries, lost of energy and small size !.
cusna
Newbie
Please write some link productors batteries zink-air
Thanks
PaulHolland
Holland
cusna
Newbie
Now I use 2x D389 Duracell button battery Silver Oxide.
I would need batteries smaller! :idea:
cusna
Newbie
Ok thanks. :D
Try even if these batteries instead of 1.55 V with 1.4 V:cry:
