Looking for a small PIC with I2C
JulioSilva
Junior Member level 2
Hello!
I'm looking for a small PIC with I2C, and at least 4 IO ports.
Can anyone tell me one?
Thanks in advance,
jS
Mr_Programmer
Full Member level 3
Re: Smaller PIC with I2C
Do you need hardware I2C? It would be easy to implement this in SW.
Regards...
sda
Member level 5
Greece
12C508-9 would do, with software implemented I2C.
Probably your cheapest option, but OTP.
Cheers
sda
JulioSilva
Hello!
Thanks for your replay's,
Yes, I'm looking with hardware I2C to make the work easier...
I'm looking for PIC16F876A I2C compatible, cause I have some code in it, and I want to port into the new one...
And it should be Flash...
Thanks anyway.
jS
gidimiz
Advanced Member level 1
This link will help you chose the right PIC for your choise.
Chose one of the PIC16Fxxx series and not the PIC16Cxxx. The C are ole type and will cost more then the F type.
Also, I would use the PIC16F88 for your applicattion. Its very similer to the 876 but smaller and only small cahnges need to be done for it to work if you have the software.
If you found my answer useful, click on the button that says Helped me.
Good luck.
    JulioSilva
JulioSilva
Hello,
I was looking for something like that PIC.
Thanks for the info.
jS
JulioSilva
Hello.
Bad news... my local resseller does not have PIC16F88...
Any other sugestion?
Thanks
jS
gidimiz
Hi JulioSilva,
As i said in my post, have a look at the link that i gave you and folow the links untill you will find what you are looking for. You know better then i what your local resseller has.
Good luck.
