Looking for a radio module for software defined radio.
cwjcwjcwj
Full Member level 5
I am a digital communication engineer. I am looking for a radio transceiver at 2.45 GHz (other higher frequency will be considered as well) which support raw I and Q data as an input for transmitter or output for receiver. So, I can generate any I and Q data and send it to the radio module for transmission. Also, for the receiver, I can process the I and Q data received from the radio module.
The idea would be similar to software defined radio but I only need the radio part cause I have a FPGA development kit.
Any recommendation?
Thanks!
not-a-moderator
Full Member level 3
South Africa
candice0929
Newbie level 3
I have a familar RF module parter at China, the name is V-chip Micreosystems,lnc.. www.digiRF.com/en/
They have RF module with 2.45 . You could contact with them.
Hope it helps.
Any recommendation?
Thanks!
cwjcwjcwj
Full Member level 5
Thanks all! I am actually looking for a complete transceiver like below:
https://www.4dsp.com/FMC30RF.php
This has an FMC interface to connect to XILINX FPGA board but other interface will be considered. I am not considering this because it is too expensive. Any other suggestions?
Would be good to have ADC and DAC included as well.
Thanks.
