[General] Looking for a micro-controller development kit (evaluation kit) with 1.2V output
Jaeyoungpark
Newbie level 3
Hi all,
I am looking for a micro-controller development kit (evaluation board) with 1.2V output.
I will use this to generate several 1.2V clocks and 1.2V dc voltages to test my chip.
Best regards,
Jaeyoung
hobbyckts
Advanced Member level 1
If you need just 1.2V output. Then Why do you need a development kit? Can you explain it clearly. If just 1.2V is required means you can go for some power supply circuit. What is the exact application of micrcontroller here?
KlausST
Super Moderator
Staff member
I assume you need a communication microcontroller to your device, while your device is supplied with 1.2V.
If so check datasheet of your device. Many low voltage devices can handle signals with higher voltage levels.
A voltage divider on microcontroller outputs may be used to decrease signal voltage.
A bjt may be used to generate a higher voltage signal from an 1.2V signal (inverting).
There are dedicated level converter ICs.
Klaus
K33rg4t3
Full Member level 3
PIC18LF2550 has operating voltage 2V-5.5V, I can't find anything for lower voltages
KlausST
Super Moderator
Staff member
Your posts are not very descriptive.
Without further information and a feedback to our posts it is impossible to help you.
Klaus
