Looking for a homemade speaker design
ultrabrains
Full Member level 2
homemade speaker
jorgito that was a very good link you sent. Itss worth the time of construction and having a good understanding of how to build even large ones
thanks
palesha
Full Member level 2
Re: homemade speaker
This speaker in the above link is ok for amatuer/experimental purpose. Not for good music listening.
ultrabrains
Full Member level 2
homemade speaker
YEs, but is a building block to great sound productio.
To improve the sound drastically, you can start by increasing the tickness of the paper, change the plastic cup to fibre and add a vibration pivot which would enable bass sound production. i will give a tutorial on how to build a better one very soon.
cheers
palesha
Full Member level 2
yes, by increasing the weight of the cone, low frequency response improves but high frequency reduces. Further u hv to check the linearity of frequency response. To check frequency response requires acoustical room & test equipments.
Hope this clarifies what i mean.
ultrabrains
Full Member level 2
homemade speaker
palesha,
Do you have a link or text on building speakers, that talks about how to increase frequency response
mhtplsh
Full Member level 3
Simply study the construction of midrange speaker & tweeter. U will understand a lot. The cone should be light & stiff/strong. This helps to get more high frequency response. Also the voice coil weight & spider stiffness plays a big role in frequency response & resonant frequency.
I hv tried to explain u in short & simple way.
There r books on this subject available with audio express.
ultrabrains
Full Member level 2
homemade speaker
thanks i will do just that
surajgagnani
Newbie level 3
it is really good as it shows how the speaker works thanx
