JoeDreck
Hello,
i am looking for an antenna which is working with a ground plane on the bottom side of the substrate (FR4) at 2.4GHz.
It will be placed on "biological objects" like human beeings. What is important for the right antenna in this case?
I found four similar patch antennas:
I think the performance should be very similar?
I what to use this antenna with a TI/Chipcon ZigBee Transceiver and a balun (75Ω to 50Ω), could i now leave out the fed lines to the antenna. Or in other words: Is the fed line for matching only?
Thanks.
- Circular inset-fed linear polarised patch
- Rectangular inset-fed linear patch
- Circular Edge-fed linear polarised patch
- Rectangular Edge-fed Patch
Thanks.
