Looking for a 1.5V microcontroller
ZeleC
Full Member level 5
hello
Im searching for a uC that operates on a 1.5V AAA batery with at least 14 in/out, spi, 8k flash memory ,256 EEPROM.
can i find such uC?
thank you.
microcontroller 1.5v
1.4V is too low as far as i know . But u can get a good number of controllers operating at 1.8 V .MSP430 is a good choice
I think rajeshkumar is right. There are several hundred millivolts dropped across junctions, which makes low voltage use difficult. If you are trying to run a micro off a single cell, may I suggest you consider 3v lithium. You could always use an up converter, but will have to contend with switching noise. If you take this approach, there are a wide range of micros that will run on 3v.
Re: 1.5V microcontroller
ZeleC said:
hello
can i find such uC?
thank you.
i'll say that please search on manufracturer's website like ATMEL, PHILLIPS etc..
0.9V Microcontroller
The C8051F9xx is the industry’s first MCU family capable of full-spec operation down to 0.9 V and up to 3.6 V, enabling single-cell battery operation as well as dramatically increasing battery life for dual-cell applications.
https://www.silabs.com/tgwWebApp/pu...lers/LowVoltage_LowPower/en/lowvoltagemcu.htm
Added after 1 minutes:
    ZeleC
