Looking for 3-phase stepper driver
walt
Member level 1
Member level 1
Stepper driver
Need help with 3-phase, 24V, 2.6A stepper driver.
Something simple and not very expensive.
Re: Stepper driver
Here is one 3 phases controler which has been build and works! I just placed the driver portion but if you want the micro (MC68HC912B32CFU8) I can place it there.. This controller is very smooth and even the power here is for a 250 Watts motor, you can taylor it to a smaller motor by changing the output FETS.
The motor I used was from Maxon (Swiss motor) but I think any other 3 phases DC motor could be used by selecting right output pair of N and P channel FETs.
Have Fun.
:p
Re: Stepper driver
It's very nice schematics.
But now I've got PCB with L6203 + L6506 for my experiments.
Is it possible to make these chips to drive 3-phase motor?
Re: Stepper driver
walt:
Yes I suppose you could use 3 x 6203 to drive a brushless 3 phase DC motor. The dowside of using it (versus 3 pairs of FETs) is that the RDSon of the 6203 is 0.3 ohm! This is very very high. If your motor has very little power then it may be possible to use the ST 6203, but I do not see any advantages compared to 3 pair of FET (milli ohms RDSon)..
Anyway have fun..
Cheers
Re: Stepper driver
What pair of FET you suggest to use?
And what about current protection in the schematics above?
Re: Stepper driver
Walt:
The above schematic is for a stepper motor, not 3 phases DC brushless.
The one I uploaded is for 3 phases DC Brushless.
In case of a 3 phases brushless DC motor the current control is generally control on each phase switching. So as soon as the the set value (motor dependant) is reach, the switch is then turned off.
As far as the pair of FETs is concerned, I used the lowest RDS on I can place my hands on. Price difference between a very low RDS on an a medium one is not that great anyway. To select a pair use tree search by function (onsemi)
Cheers
Re: Stepper driver
Henrik:
I have some achievements while using L6203 + L6506.
The motor is rotating and has enough strenght, but the heat sink is rather hot ( about 65 Celcium ). Is it normal?
How can I reduce current while holding the motor? Now I rely on L6203 current regulating capability.
