Vitor Przedzmirski
Hello guys, I hope you can help my with this question:
Considering a very simple current mirror circuit, with A diode-connected and B mirroring its current.
A and B have multiplier = 2 and their W/L is 1um/10um.
I would like to know which of the following configurations you like the most, considering the position of the dummy transistors, and why =D
From my knowledge, I would go for the second one. I always saw layouts (considering transistors with W > L) where the dummy is abutted/next to drain or source, so it "protects" the diffusion, which does not happen in the first option.
However, I also saw in layout reference books and some presentations that in this same configuration, the dummies should be added like in the first picture...
What can you tell me about this? The other option is just put dummies all around, but there is the area trade-off and other considerations...
I appreciate if you could help me.
(this same discussion applies to cross-coupled layouts!!! )
Thank you! :-D
Thank you! :-D
