Long leads Vs short lead compnents
myatham
Member level 3
Member level 3
India
I have to choose one out of two fuses. Both are same except in the length of the leads. Which one will be the best choice and why?
Please help on this to resolve this issue.
Thanks:???:
tpetar
Advanced Member level 7
Pancevo-Belgrade, Serbia
Thanks:???:
Post photo. What type of fuses?
Longer contacts can drain heat from fuse. Bigger contact area of legs can keep fuse box/place cold to avoid melting.
But best is to see photos of fuses and fuse place holder.
myatham
Member level 3
Member level 3
India
These fuses are thru-hole fuses. As per my knowledge, after getting soldered into the PCB, the extra lead will be cut off from PCB.
See the pics attached.
picgak
Advanced Member level 1
length doesnt matter unless you are dealing with high current and voltage
