Register Log in
Logical effort and parasitics with HSPICE
akis
Junior Member level 1
Hello guys!
I have a big problem and i need some help. I im working on a project and i have to find the parasitics(p) and logical effort(g) of standard cells with HSPICE. I have read the book of Waste-Harris especially the chapter 5 but it didnt help me a lot. This is a sample code of AND2_X1.sp file as i take it from Nangate Cell Library:
.GLOBAL VDD
.GLOBAL VSS
* Cellname: AND2_X1. *
* Technology: NCSU FreePDK 45nm. *
* Format: Default. *
.SUBCKT AND2_X1 A1 A2 ZN VDD VSS
M_i_0 net_001 A1 net_000 VSS NMOS_VTL W=0.130000U L=0.050000U AS=0.008450P AD=0.008450P PS=0.260000U PD=0.260000U
M_i_5 VSS A2 net_001 VSS NMOS_VTL W=0.130000U L=0.050000U AS=0.008450P AD=0.008450P PS=0.260000U PD=0.260000U
M_i_11 ZN net_000 VSS VSS NMOS_VTL W=0.090000U L=0.050000U AS=0.004050P AD=0.004050P PS=0.180000U PD=0.180000U
M_i_18 net_000 A1 VDD VDD PMOS_VTL W=0.135000U L=0.050000U AS=0.009112P AD=0.009112P PS=0.270000U PD=0.270000U
M_i_25 VDD A2 net_000 VDD PMOS_VTL W=0.135000U L=0.050000U AS=0.009112P AD=0.009112P PS=0.270000U PD=0.270000U
M_i_31 ZN net_000 VDD VDD PMOS_VTL W=0.135000U L=0.050000U AS=0.009112P AD=0.009112P PS=0.270000U PD=0.270000U
.ENDS
* END
Except from the parameters that i have to add to this code for simulation what else i have to add so i can compute the logical effort and the parasitics?
Please help me if you can because that is important for the next steps of my project. :???:
leo_o2
China
I think you should read HSPICE manual.
Please add ".tran" for simulation and ".print" for output.
akis
I read the manual of Hspice and this is the new version:
.OPTION POST
.INCLUDE 'C:\NangateOpenCellLibrary_PDKv1_3_v2009_07\NangateOpenCellLibrary_PDKv1_3_v2009_07\technology\models\hspice\hspice_ss.include'
.GLOBAL VDD
.GLOBAL VSS
.ENDS
* END
Vdd VDD VSS 1.25V
Vin A1 VSS PULSE 0 1.25V 0ps 20ps 20ps 120ps 200ps
X1 A1 VSS B1 VDD VSS AND2_X1
X2 B1 VSS C1 VDD VSS AND2_X1
X3 C1 VSS D1 VDD VSS AND2_X1
X4 D1 VSS E1 VDD VSS AND2_X1
x5 E1 VSS F1 VDD VSS AND2_X1
.TRAN 1ps 200ps START=0ps
.END
Now i have a problem with the topology of the circuit.
I tried to create the topology of waste and harris's book example:
But hspice returned a lot of errors. Where should i connect the second input of every NAND gate?
leo_o2
China
Do you set VSS to 0?
And please post the error information.
akis
new code with VSS=0 and second input of AND to VDD but it returns the same errors...
.OPTION POST
.GLOBAL VDD
.GLOBAL VSS=0
.ENDS
* END
Vdd VDD VSS 1.25V
X1 A1 VDD B1 VDD VSS AND2_X1
X2 B1 VDD C1 VDD VSS AND2_X1
X3 C1 VDD D1 VDD VSS AND2_X1
X4 D1 VDD E1 VDD VSS AND2_X1
x5 E1 VDD F1 VDD VSS AND2_X1
.END
**error** no dc path to ground from node 0: a1
**error** no dc path to ground from node 0: b1
**error** no dc path to ground from node 0: c1
**error** no dc path to ground from node 0: d1
**error** no dc path to ground from node 0: e1
**error** no dc path to ground from node 0: f1
**error** no dc path to ground from node 0: vdd
**error** no dc path to ground from node 0: vss
**error** no dc path to ground from node 1: net_000
**error** no dc path to ground from node 1: net_001
**error** no dc path to ground from node 2: net_000
**error** no dc path to ground from node 2: net_001
**error** no dc path to ground from node 3: net_000
**error** no dc path to ground from node 3: net_001
**error** no dc path to ground from node 4: net_000
**error** no dc path to ground from node 4: net_001
**error** no dc path to ground from node 5: net_000
**error** no dc path to ground from node 5: net_001
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
Try
.GLOBAL VSS
Rather than
.GLOBAL VSS=0
And add
VG VSS 0 0
Keith
Reactions: r_usso
    r_usso
leo_o2
China
Agree with keith1200rs for correct gramma.
akis
Thanks guys, now it runs without errors except this warning:
**warning** the following singular supplies were terminated to 1 meg resistor
supply node1 node2
vg 0:vss defined in subckt 0 0:0 defined in subckt 0
I think its not a big problem.
what exactly is VG in: VG VSS 0 0?
Now do you have any idea how to find parasitics and logical effort?
Should i put this in the code as shows the book of Waste&Harris?
.measure tpdr * rising propagation delay
+ TRIG v(c) VAL='SUPPLY/2' FALL=1
+ TARG v(d) VAL='SUPPLY/2' RISE=1
.measure tpdf * falling propagation delay
+ TRIG v(c) VAL='SUPPLY/2' RISE=1
+ TARG v(d) VAL='SUPPLY/2' FALL=1
.measure tpd param='(tpdr+tpdf)/2' * average propagation delay
.measure trise * rise time
+ TRIG v(d) VAL='0.2*SUPPLY' RISE=1
+ TARG v(d) VAL='0.8*SUPPLY' RISE=1
.measure tfall * fall time
+ TRIG v(d) VAL='0.8*SUPPLY' FALL=1
+ TARG v(d) VAL='0.2*SUPPLY' FALL=1
leo_o2
China
That warning means a voltage source is floating.
I suggest you read thru the completed HSPICE manual for detailed syntax.
akis
now i have no problem with the syntax.
but the main problem is how to find now the p and g?:!:
is this code useful for this problem?
leo_o2
China
I can't understand your meaning for "p and g".
The time measurement should be correct.
akis
i mean p(parasitic delay) and g(logical effort) of a standard cell library.
Thats the main problem as i wrote at the first post.
erikl
Super Moderator
Staff member
Germany
... how to find now the p and g?
It's all described in the Weste/Harris book, s. here: View attachment Logical_Effort.pdf .
You should run the same simulation analyses corresponding to Fig. 5.28 for fanOut 1..n (1..8 in Fig 5.28 (b) , maybe n=4 or 5 should be enough) ...
  • for your AND2
  • for the smallest INV
  • from their slopes ratio you'll get g
  • then do the same without any load after your DUT (i.e. without the X4, X5 gates)
  • then from their (AND2/INV slopes) ratio you'll get p
akis
It's all described in the Weste/Harris book, s. here: View attachment 61439 .
  • for your AND2
First of all the pdf file was damaged and i couldnt open it.
I read the book of waste-harris and i understood how to continue with this process.
I run this code:
.param SUPPLY=1.25V
.OPTION POST
.GLOBAL VDD
.GLOBAL VSS
VG VSS 0 0
.ENDS
* END
Vdd VDD VSS 'SUPPLY'
Vin A1 VSS=0 PULSE 0 'SUPPLY' 0ps 20ps 20ps 120ps 200ps
.END
is this code correct for logical effort?
Or i have to add new code?
Like this:
Can you help me please, because i have to finish the project next monday.. :sad:
And finally how i will find the slopes that you describe above?
Thanks erikl.
erikl
Super Moderator
Staff member
Germany
Of course you need the 'measure' statements. tpd is what you need for the ordinate dabs in FIG 5.28 (b) .
As I told you above. Read thoroughly!
akis
I added this code:
.measure tpdr
+ trig v(c1) val='supply/2' fall=1
+ targ v(d1) val='supply/2' rise=1
.measure tpdf
+ trig v(c1) val='supply/2' rise=1
+ targ v(d1) val='supply/2' fall=1
and .lis file doesnt return right value for tpd:
****** transient analysis tnom= 25.000 temp= 25.000
tpdr= -1.1874E-10 targ= 8.0431E-11 trig= 1.9917E-10
tpdf= failed targ= not found trig= 5.6558E-11
tpd= failed measure parameter failed
Is soething wrong with the code?
Or the topology of the circuit?
erikl
Super Moderator
Staff member
Germany
Is soething wrong with the code? Or the topology of the circuit?
Circuit topology is ok (for fanOut=1). But for propagation delay measurement (tpd.) of a non-inverting gate (your AND2) you have to measure the tpdr from rise to rise and tpdf from fall to fall.
I really wonder if you know what you're doing?
akis
the truth is that hspice is not familiar to me..but i try it..the problem is that i havent plenty of time to learn all the hspice manual.
to the point now..
I tried this but again tpdf= failed and targ= not found therefore tpd failed.
I tried with inverter and NAND2 and i got tpdf tpdr and tpd without any problem.
whats going on with AND2?
erikl
Super Moderator
Staff member
Germany
You don't need to learn all the hspice manual. But you should essentially know what you want to measure!
Did you measure from rise=1 to rise=2 , and from fall=1 to fall=2 ?
Of course, because the measurement statements had been created for an (inverting) NAND gate!
This is a non-inverting gate, so you have to measure propagation delay times from first rise to second rise, resp. from first fall to second fall:
.measure tpdr
+ targ v(d1) val='supply/2' rise=2
.measure tpdf
+ targ v(d1) val='supply/2' fall=2
