Logic Synthesis for small rtl, correct synthesis netlist
engr
Member level 3
Hi all,
I am doing logic synthesis for small rtl, i created dc scripts for it and ran dc, i seen timing, none of timing paths vilolated.
Area constraints is violates, since i set max area to 0.
What are the the other things i have to look at , to conclude my synthesis netlist is correct apart from timing and area constains.
i have to look at netlist for any reason, to find out any issues in netlist
arjun1110
Bangalore,India
Re: Logic Synthesis
Do LEC(Logical Equivalent Check) between RTL and Netlist to check both the netlist are equal.
Regards.
Syswip
Re: Logic Synthesis
Hi engr,
After compile you should run and analyze several commands:
check_design
check_timing
report_constraint -all_violators
report_timing -loops
These are more important things to be checked.
engr
Member level 3
Re: Logic Synthesis
I have generated reports for all the above said
check_design
check_timing
everything fine regards to above commands , and i also did formal verifcation of rtl and netlist, its passing.
is there any thing that i have look at
Thanks in advance
engr
Member level 3
Re: Logic Synthesis
i am looking at the synthesis reports and concluding my synthesis is corect, is this corect way or should also look at netlist and check something there manually
Syswip
Re: Logic Synthesis
No you don't need to check netlist manually.
The only thing you can do try to simulate your netlist. And that's it. You're done.
engr
Member level 3
Re: Logic Synthesis
try to simulate netlist?
Can you please elaborate, what it meant by simulating netlist ?
Thanks in Advance
Syswip
Re: Logic Synthesis
The same as simulating RTL :D
Change RTL by netlist, include Libs and run your verification as you did during RTL.
You verification environment should be designed to support timing simulation.
aaronhe
Junior Member level 2
Shenzhen in China
Logic Synthesis
If you have spyglass, you can run it to check your netlist's robustness
