MobiNaz
Full Member level 3
Hello all,
I am trying to bias a diode by a photodiode under illumination. If I measure the voltage generated by the photo under laser illumination, it gives me 480mV.
But then I introduce the diode in parallel to the diode (thats how it is going to be)
Photo|| Diode
The voltage across the photo reduces to 200mV and the current is less then what I require. Reducing of photodiode's voltage indicates that the diode resistance is less than that of photodiode. But less current indicates that the diode resistance id high such that it draws less current.
How do I cater this problem?
Introduce a resistor in parallel such that I and V become what I require, increase the photodiode intensity or area, have I understood the problem correctly?
Thanks in advance.
Photo|| Diode
Thanks in advance.
