Loading data from server using GPRS
eng_ahmed22
Full Member level 4
Hi everybody
The attached file shows a block diagram of an embedded system.
It is supposed the user log in to the server and update data stored into a file, then, the embedded system connect to the server through GPRS using module to load that file and analysis the data stored in it, and according to the analysis, the output will be generated.
the user may have many systems, each one will load the same file according to timing plan.
The GSM/GPRS module has a tcp/ip protocol stack.
the question is: what is the best and easiest way to load the file from the server?? and what protocols should i use??
thanks and best regards
