juicedry
Junior Member level 3
- Joined
- Oct 4, 2014
- Messages
- 25
- Helped
- 5
- Reputation
- 10
- Reaction score
- 5
- Trophy points
- 3
- Activity points
- 167
I am designing a circuit to charge 4V battery cells from PV solar panel. The peak current will be about 300mA. The charging cycle is being controlled by a dedicated uC. My question is what is a good load switch (MOSFET, BJT, dedicated load switch) for this circuit?
When the battery cells are discharged, the load switch needs to pass current through to the PV solar panel and start charging the battery until it is above the uC supply voltage to turn-on. Then the uC can control the charging cycle. Also if the battery is charged to greater potential than the PV solar panel, then the load switch must block the reverse leakage current.
The PV solar panel will be manually connected and disconnected by the user and it will be operating in hot climates, so potentially +50degC ambient temperature.
Overall, it needs to be a cheap solution.
