load regulation of LDO
rock_zhu
Hangzhou,China
load regulation
Hi all
I designed a LDO with 100mA max drive current and 1.2V output.I add a buffer between error amp and PMOS transistor.But when i do load regulation simulation the regulator output voltage is 1.3V at 1uA load current and 1.2V at 50uA or larger load current.
so why the curve like this? Does PMOS size too large or loop gain decreasing?
How can i get a stable 1.2V output voltage over the 0->100mA load current range.
Thanks advanced.
ldo load regulation
That drop is due to dc load regulation.To provide the high current value(more than your quiscent current), there will be certain drop across your PMOS o/p device..Usually dc load regulation will be a spec for your LDO.
    rock_zhu
load regulation of ldo
thanks.
yes,this method is work by double the that branch's stastic current (10uA->20uA)but the whole current dissipation is limited, any other method?
load regulation for ldo
hello
try to increase overall loop gain to achieve better load regulation
regards
    rock_zhu
ldo regulation
jutek said:
hello
regards
Thanks. but if i increase the loop gain it is difficult to compensate although i add a buffer between error amp and PMOS. I find that the unit gain OTA buffer is diffcult to design in cmos standard process because the comon input voltage limitation.
nmos ldo operation point
What type of buffer you are using in the LDO?Is it a source follower (PMOS/NMOS) with unity gain or is it a gain stage (common source)?
ldo nmos operation point
It is a unit-gain configuration NMOS input differential OTA. The input NMOS's Vth is high due to body effection. so the common input voltage is limited so as output voltage of buffer.
ldo source follower
Take a look on the operation point difference under different load condition.
If it has no problem, maybe you have to increase your loop gain such as using a bigger pass element.
load regulation in ldo
loop gain and transconductor of pass element will both influence the load regulation.
