thudson
Newbie level 1
I am building a simple op amp circuit to double the input voltage. The input range is 0-5V and the output is 0-10V. After building the circuit, the output will not go below 3.9V, even when the input is below 1.95. Even with 0V input, the output always remains 3.9V. At input of 2V and above, the output is double the input, as expected. The configuration is attached. I'm using 12V for V+ and 0V for V-, R1=R2=10kOhm. Any help is appreciated.
