LM35 WIth pic16f877A - LCD it is not showing (using C)
ADDE
Newbie level 2
HI all.
I am New in here n Also Very New in Controller i have programmed my controller Using C but the problem is that in the LCD it is nt showin the correct value when i increase the Tempreture or press the positive one it will jump two value and displays the Even Values only....
I need Help as soon PLz the due date is Less u can feel it as student.
thnz even for ur reading
ratheeshbr
Member level 1
HI all.
Me too having the same problem!
engshahrul
Banned
Malaysia
Sorry I dont get anything from the link( that website);
Only a program
Yes, just take the source code.
Someone give for the theory, then asking for source code. Giving the source code, then asking for another else.
ratheeshbr
Member level 1
I think My program side is ok. I am writing pgm using CCs compiler. What my doubt is the variation in the output of LM35. Temperature is varying between a range of 4- 5 degree Cel:
karthikkrv85
Full Member level 3
bangalore
please upload your code as well as the circuit. That may give us some clue to help you
ratheeshbr
Member level 1
#include<16f877a.h>
//#device adc=10
#include"pic.h"
#include"lcd1.h"
float x,tempread;
int i;
float temp()
	set_adc_channel(4);
	delay_us(20);
	x=read_adc();
	delay_ms(200);
	return(x*1.96);
	delay_ms(500);
void main()
	float T;
	setup_adc(ADC_CLOCK_INTERNAL);
   	 setup_adc_ports(ALL_ANALOG);
   	 lcdinit();
  	go(3);
	printc("Temp Sensor");
  	delay_ms(1500);
 	delay_ms(1500);
	clrscr();
while(1)
	go(0);
	printc("Temperature=");
	go(12);
	print(temp());
	delay_ms(1500);
---------- Post added at 17:01 ---------- Previous post was at 17:00 ----------
Circuit is nothing but output of LM35 directly connected to RA5 of PIC 16f877a
