kdg007
Full Member level 3
I am trying to amplify the signal from photodiode(used LED as transmitter) using the comparator.as you can see,i have used 1M pot for the -ve terminal.I have checked the voltages of both inputs of comparator before giving the signal , 0.5v at -ve input and 0.5v at +ve input(using the 100k pot,i have changed the voltage).I am unable to get the desired signal at output pin.
Signal from frequency generator -> 5v/div (1cm block in CRO)
signal from photodiode -> 50mv/div (1CM BLOCK IN CRO)
please help !!! is something i am missing ?
thanks in advance.
