i have built audio amplifier based on lm1875 which output 20w power, its working fine. now i want to drive 2 speakers of 10w each instead of a single 20w speaker, can any one advice if i connect two 10w speaker at output of lm1875?
thanks
Use 2 speakers with half the resistance of that which you have used, and connect them in series. Or you can use 2 speakers with double the resistance of that which you have used and connect them in parallel.
