hi ...
am trying to design a comparator circuit and its output should be fall between 0 to 5v.. here am attaching my circuit and output wave form am getting the output between 0 to -5v.. what should i do in this circuit to get a output between 0 to 5 v..
The LM393 comparator has an 'open' output, so it requires a pull-up resistor to +Vsupply. You may choose the resistor to give about 5mA thru the resistor.
