cupoftea
Advanced Member level 5
Doing LLC with Vin = 390VDC and Vout = +/-180Vdc at 4kW.
The simple 2 diode output rectifier suffers high ringing voltage on the output diodes when the respective diode switches off.
However, the full bridge LLC suffers none of this, and as such, lower voltage diodes can be used. Would you agree that overall, the full bridge approach is best?
(apart from different cases when Vout is low and Iout is very high, granted)
Attached shows the LLC with full bridge and simple 2 diode bridge in LTspice and jpeg
The Full Bridge output LLC suffers absolutely no output overvoltage ringing at all.
