24vtingle
Advanced Member level 6
The attached is a 1kW Full Bridge LLC sim 390V to 60V, 80kHz.
The LLC is switched at 80kHz continuously, no matter if full load or no load.
When no loaded, the LLC output creeps up. Its as if it needs a 0.5W dummy load resistor
, or "regulator", to dissipate this "excess no load current".
Have you known LLC's which cause a higher rate of rise of vout when in no load?
What's the maximum dummy load that would be needed to keep such an LLC from rising its Vout
continuously higher?
We do not wish to go into burst mode in no load. The output regulation is very tight from full load to no load considering there's no feedback.
And the pre-charge on Vout means there is no overcurrent in the primary at startup.
