Lithium Ion Battery charging
chanchal.chauhan
Full Member level 4
Hyderabad, India
Hello Guys,
I want to understand more about lithium Ion charging with CC-CV mode.
what is the main difference b/w CV mode and CC-CV mode charger?
Microcontroller is good solution for CC-CV mode charging?
What ckt i have to use if i will do CC-CV charging with micro controller.
Battery will charge with solar panel & grid with ac-dc adopter.
Please share your ideas.
Regards
Chanchal
without knowing what you meant by "good", anything can be "good" to some of us, while "bad" for others.
I was dealing with this issue in my senior design project. The easiest way to come over this issue is using battery management or power management ICs. Check TI and Microchip for your desired specifications. As far as I can remember, there was an article about this on "Power Magazine". if you search, I believe you can find it...
