Audette
Newbie level 6
I have a question about batteries and how much energy they store.
I am looking at using a Lithium battery for a portable instrument - the two choices I have are 14.8V 4.4Ah or 11.1V 4.4Ah.
The voltages I work with are 5V and 3.3V and generally the instrument will use around 400-500mA during normal usage. My question is, does the voltage have an effect on how many cycles my battery can go through? Someone once told me voltage makes very little difference to the energy within batteries and that it is the Ah specification that matters. However I never really got a proper explanation as to why this is and I am yet confused as to whether this is the case.
I was hoping my instrument should be able to cycle around 200 iterations using the 14.8V 4.4Ah battery. How would this be affected if I go to the 11.1V 4.4Ah battery - or even a lower voltage but same Ah.
Thanks in advance
Thanks in advance
