Register Log in
Linux Command to Copy Multiple Files?
emaq
Member level 2
In CentOS, I want to copy a rubric.docx file to multiple files with names such as F20161368.docx, F20161981.docx, F20161983.docx... from a list of names in a MS Excel or text file.
Please help with a command or script to do that.
std_match
Sweden
cat destination_file_list.txt | xargs -n 1 cp source_file
Edit: the "-T " option for cp isn't needed, so I removed it.
Reactions: emaq
    emaq
emaq
Member level 2
Where the files have been copied?... I couldn't find them!
I used the following command...
cat /home/user/Desktop/temp/list.txt | xargs -n 1 cp /home/user/Desktop/temp/rubric.docx
std_match
Sweden
If there is no path in the destination file names, they should go to the current directory.
dick_freebird
Advanced Member level 5
USA
If it were me, I'd get the file list as plain text from
"wherever", and edit it into a shell script with vi / vim.
Then run it.
:1,$s/^/cp \/home\/user\/Desktop\/temp\/rubric.docx &/
would make
F20161983.docx
into
cp /home/user/Desktop/temp/rubric.docx F20161983.docx
and all the other lines in the file, similarly.
I'm sure there's an elegant way to do it but I'd rather
get it done that figure out pipes and whatnot. You could
probably do a foreach x( {list} ) or something. But I find
it easier to work on a script in a text editor, than to get
100.00% correct command line typed out, first try.
emaq
Member level 2
the command worked... thanks. However, the files created have no extension. How to have .docx extension of the copied files?
std_match
Sweden
The file names will be exactly as in the "destination_file_list.txt".
If the file names in the list don't have the .docx extension, you can add it with the "sed" command:
cat destination_file_list.txt | sed "s/$/\.docx/" | xargs -n 1 cp source_file
Toggle Sidebar
